Similar problem to walkman issue
jacek_go
Hello, I've got problem with walkman mentioned earlier, I've noticed as well similar problem with walkman, I use "air droid" - app to control phone with internet browser. When the screen is on everythings goes perfect, when the screen goes off comunnication is broken, when I press power button everything is ok till the screen is on. Exactly the same as with walkman app. I think some processes go to sleep too deep. Network connetion functions ok when the screen is off. I don't use extended standby mode (ESM).
I 've noticed that in ESM led notification not works. In my opinion this is too aggresive mode.
Regards
2 REPLIES 2
Johan
Are you connected to Internet via Wi-Fi or mobile networks?
If Wi-Fi make sure that the Wi-Fi policy is setup to be on even if you turn off the screen.
jacek_go
I connect to Internet via Wi Fi, I establish connecton in local network, Wi Fi policy is setup to "always" when the screen is off, As ia wrote above network connection works when the screen is off, I can "ping" my xperia by ip address when the screen is off but comunication with airdroid is freez. When I press power button and screen go on airdroid comunication restore. I've found in airdroid option to "leave screen on" then everything goes ok, but it drains battery.
