My new Xperia J (a month old) is suddenly not recognizing the sim card, I tried with an alternative one, but the problem persists. If I restart it works for a min and then there is no signal. I tried to resetting the phone to factory settings - it worked for a few hrs but again the same problem. How can this be resolved quickly.
Thanks
I'd recommend that you try to repair the software via PC Companion. Download and install PCC from there:
If the problems still persist after the update, you should send in the phone to a service center for repair.
