Hello,
I have a problem with my z1 compact and my SIM card. Phone doesn't recognize the sim card. When I restart it, it shows a dial pad for a second or two and then it disappear. I cannot write the PIN and when I go to the network it says that there is no SIM card. Also the home button and the multitasking button doesn't work. SIM card is fine and if I put some other SIM card in the phone, it doesn't recognize it.
I already had this problem and it was on the repair service but all they did was hard reset and it worked fine. I don't want to do that every couple of months. Is there any other way of fixing the issue? Is this software issue? Or hardware? I would say software, as the hard reset fixes the issue.
Please help.
Thank you
How old is the SIM card?
Is a MICRO SIM card or did you trimmed it?
SIM card is as old as the phone. It's Micro SIM, it's not trimmed.
I did a hard reset and now everything works again. SIM is recognized, home button wokrs as it should. So there is a software problem. Anyone has any ideas about the issue?
Cheers
I've seen this before and it was an app acting up, an antivirus or taskiller
You could also try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so if you can then it's best to backup before you begin
Thanks for all of yours replies. I already did a hard reset yesterday, so I'll have to wait until the next time it happens. I cannot connect it to the computer, because Sony doesn't want to make a linux version of PC companion and I use Ubuntu.
So it is a problem with one of the apps? But I installed all of the apps that I had before this happend and now it works nice.
I'll try safe moode before doing hard reset - next time
ps. I don't use antivirus nor taskiller.
Again hello. I might just discovered which app is joking around with my network. Yesterday I had been losing network connection. Network was unavailable every couple of minutes. It would connect back, but it was frustrating. I was using Hi Locker app and I closed it (stoped with the usage) and now network seems fine. I'm not losing the network. I cannot be sure if this one is right one with the SIM card problem, but at least it work better for now. Will be back, if I'll have more problems. Thanks
