Shutdown Z3 Dual And then Can not Turn on it
malavanehsan
Hi
I put shutdown and Volume Up For 10 Sec
And i can't turn on it Please Help me
When i Shutdown It have 55% Charge
9 REPLIES 9
MarkMRL
Connect the charger and leave it there for a while and try again. Then try again with volume up + power button but hold until you feel a vibration then 3 consecutive vibrations.
If none of this works your phone died and you need to get it replaced.
You can also try a pc companion repair but honestly I wouldn't even bother since it's definitely a hardware issue.
malavanehsan
When I connect Charger The Charge notifation and Lcd not be turn on it
Thommo
Genius
Did you hold down both the power and volume up buttons as detailed above
malavanehsan
yes but not turn on
Isac
You can fix it with pc companion. Launch the pcc on your pc and connect your Xperia phone with genuine cable, then press and hold power and volume up until u get blue light on your phone. U may fail one time, don't worry try 'till you get that light. Now go to pcc and click on support zone and click update handset or update accessories then follow the instructions. Be sure you have good and permanent Internet connection. GOOD LUCK!
malavanehsan
I do this But the Light not Be turn on
ABR
Z3 dual Sim phone ussd not working after updating to 5.1.1. I need help to fix this problem. Can't check balance or even load Internet bundles etc in Kenya.
titijuli
Same here.
This mornig i tried to swich off the alarm and couldn't. I tried to switch off my xperia and couldn't. Then i pressed power+ vol up and the device switched off and i have no clue how to switch it on again.
i've tried every thing but it does not turn on. Battery was 80%. and never been putted under the water.
any clues?
titijuli
OK,
I did fix it by pressing the yellow button (inside the simcard slot) for 120 seconds. Then i connected to the USB cable to the computer and the mobile restarted... luckyly
