Shortcut to settings *submenu*
mickangel
Hello,
I'd like a homescreen shortcut to a settings submenu - in this case Settings/Power Management/Stamina Mode. What I'd like to do is be able to switch stamina mode on a off with a simple toggle from the homescreen.
Is this possible?
Thank you.
3 REPLIES 3
Hampus
From the homescreen, place your finger on a free spot for a while and then choose Apps > Shortcuts > Settings shortcut > Power management.
mickangel
Hello,
I know I can have shortcuts to a menu item, what I wanted was a way to link a shortcut to the Stamina on/off sub-menu of Power Management, so that I could turn stamina on and off with a shortcut.
Any other ideas?
Hampus
Unfortunately there are no shortcut for this function to turn the STAMINA-mode ON/OFF with one click. The closest you'll get to this function is the solution I gave you.
