I use a dock DK22 for my TX and some applications see then inverted(inverse bottom up),like TV programms,etc.What settings should I do for normal to see them? in landscape,of couse? Regards!
when you say "inverted" do you mean on "Portrait" mode not on landscape? if so, not all will rotate. which apps are not rotating?
No portrait,landscape but inverted! Application like Online Tv,TV Wave etc.
does this happen when its connected to the dock or even if its not connected to the dock?
no,just when is connected dock!
I can't send a screenshot from my laptop because when I try to add a photo from my laptop,the site don't allow this.Just throw a mail adress.
you can upload them to picasa, G+ or even box and share the link here
it seems to be the app's issue, it only rotates landscape rotating your phone to your left the same is true with some games
Well,it's something to do in this case?
