Setting up e-mails on X10 mini pro
This is driving me crazy! I got this phone to keep in touch with activity on the web forum and my e-mails for the charity I do work for (in between my normal job!!)  But every time I try to set up my e-mails I get an error message stating "certificate error.  Check that time and date are correct"  well, I have and all is OK but am going round in circles - anyone had this problem and what did you have to do?
3 REPLIES 3
i haven't had any problems as such with the stock email app, however it doesn't automatically check for mail, you have to do it manually. so i downloaded k9 mail from the market and its pretty good, so you could give that a try.
Thanks it is working with K9. Many thanks for taking the time to help
I have the same problem, I guess your email account (as mine) has a certificate from an untrusted source
so there should be a way to accept the certificate or add it manually.
So, is there a way to manage certificates?
