Serious Charging Problem
Karan_Yaduvansh
My Xperia U Is Not Charging When Connected To Wall Charger Or USB But Its Charging Well When Switched Off I Also Reset It But Same Result And I Also Tried Repairing It By PC Companion Bt Its Getting N Error.My ICS Build Number Is 6.1.1.B.1.10.When Will New Update Gonna Release Coz There Is No Update Since Last September
7 REPLIES 7
Karan_Yaduvansh
7 Hour Still No Reply Shame On You Sony
chelaka
hi sometimes even though the phone is actually charging, it wont show up on the battery meter.... but the phone still charges so... every time this happens dont worry just re-start your phone everytime this happens ...  Slightly_smiling_Face  try this and see the next time this happens hope i helped
Karan_Yaduvansh
I Know It Bt It Still Not Charging Even If I Restart It.It Only Charges When I Shut It Down
chelaka
no no i mean leave it to charge even though ur phone wont show it... ( say its at 30 % ) after you are done charging for a while remove the phone and then re- start it should have increased then..
NaxoLopz
I have the same problem. I always need Switch Off the mobile to charge!!!! Could it be to upgrade to ICS?
chelaka
no i dont think so i had this on gongerbread as well.. but now after ics i dont seem to be having this Anguished_Face
NaxoLopz
chelaka, With GB appears the problem and now with ICS no appears????
I'm going to official sony center. This is not normal.
