Hi guys,
There is a serious bug in ICS 4.0.4 . When you switch on bluetooth, the phone gets hanged and then goes into infinite loop of rebooting.
We need to remove the battery to stop this continuous rebooting. I have observed this almost 3 times. But it doesn't happen everytime you switch on bluetooth.
I think it also happens when you are using switch widgets for switching on and off bluetooth. Now, i have to flash ICS to use my phone. :smileysad::smileysad:
Sony find some fix for this....
I guess you need to repair your software using PC Companion
See if it helps
________________________________________________________________
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions
My phone doesn't start dude. I have to first flash ICS then i can do repair.
Can rooting be cause of this issue ?
ajayw6 You don't need your phone to be swicthed on
Just let it remain off and follow the insctructions above
Use SUS
Nopes, rooting shouldn't be a cause
Ohk.. Thanks a lot.. i will try this.. hope this solves the problem.
I have got same problem of rebooting by turning of Bluetooth last week and also my memory card has DELETED and I lost all my data and it has not recovered, so I bought a new one. I then flashed my phone and installed GB from service center and it solved. Sony should fix this issue as early as possible as we have to pay for it.:smileyangry:
