yesterday night, the battery level was around 50 I plugged in the charger and switched off my phone (to charge it overnight).
when i tried to turn it on today morning it didn't start. (I also noticed that the notification led was not glowing). I unplugged and plugged in the charger. the led started to glow but the phone started after 3 mins and it had only 1 percent battery.I saw the battery statistics later, it showed a sudden drop to 0 at the time when switched it off.
is it a software bug or has my battery gone bad?
you say that the battery level indicated was wrong?
ok, but why didn't it get charged whole night? why did go to 0 instead of 100?
btw i'm not using any task killers, antivirus, or power saver apps.
I didnt mean that ! Battery Level Indicated is absolutely right and this is a dangerous s/w bug. Voltage drop is accompanied by severe heating that proves battery is really draining !
battery issues are not resolved in the latest update. my battery graph shows sudden ups and downs (without connecting the charger), and the battery drains faster than usual.
holy s*** LOL
I had the same problem but SOLVED it!! I went to the sony center and he downgraded the software to the 162 firmware which helped a lot also i found some neet tips while searching online. here http://40marks.com/xperia-u-xperia-p-battery-problem-solved/
but the .162 firmware has many other bugs too...the network drop being the major one......so this was not good on the part of sony service centre.
