serious battery issues needs to be solved
joycetan_26
hi, i just bought my Xperia acro s on november 2012, but i've met with a battery issue now that needs to be solved.
i've charged my battery for 6 hours in row (maybe more) from 6% but it can't seem to be fully charged. i've removed any on going apps on the list and even restarted my phone but it doesn't solve the problem anyway... its always showing 83% of battery left and even though battery widgets shows that it is still charging...
may i know what caused this problem since the phone is still considered newly bought and here comes the battery issue, and may i know how this issue could be solved? reply as soon as possible as i'm scared that over-charge would affect the battery health, thank you 😃
2 REPLIES 2
WuOne
Try to connect phone to PC, sony PC companion can be installed directly from the phone.
Check settings>xperia>connectuvity, Install PC Companion have to be checked
Connect to PC install PC companion, backup your phone and reinstall the software, then restore from backup. You will have to install all the apps again (better before restoring from backup)
Might help.
Waqas
I've already done that 4 times now.
Its nothing more than a temporary fix.
Could it be something terribly wrong with the HW or SW ?
