Hi folks,
got my Xperia U 3 days ago, out of the box I used it till the battery was dead and charged it fully and did that process again.
Now yesterday I had 50% charge and it went from that to 0 in no time and turned of. Today it happened again.
Can someone help me please?
Thanks in advance.
I'm going to wait untill the battery is fully charged untill I connect the device to my Mac.
Your help is greatly appreciated.
let me know if you need any more help, don't forget to post the screenshots
Don't forget to mark theCorrect Answers & Helpful Answers
If the device can get to 10% I will to that, although I hope the repair will fix this issue.
Anyhow, I will get back to you, many thanks!
Sony Bridge for Mac Says: "There was an issue with the update engine. Please contact technical support."
bummer, what's going on is that the servers are busy, try a bit later or if possible borrow a PC
I'll try again tomorrow, it's getting late here in Belgium
BTW, does the battery need to be fully charged to do this process, I don't know where I got this assumption from?
ok, keep us posted
So, up untill now the only change I made is deleting the McAfee app. Is this app pre-installed in all regions?
But ok, the battery has gotten from full to 27% untill now. If it reaches 10% should I still take those screenshots?
From http://service.mcafee.com/FAQDocument.aspx?lc=1033&id=TS101230
Will McAfee Mobile Security drain my battery faster?
Battery drain is negligible. With normal use, the device battery drains only 5 percent faster when McAfee Mobile Security is installed. If you have an Android tablet that is not push-enabled, your battery might drain faster because of higher data use. Also, your battery may drain faster if you have automatic scan enabled.
And bummer, around 20% the device turned off without warning.
