Sending phone problem
regalxdomain
I am trying to transfer from an gzone commando 4G and when I get to the part when you can need to selct pin or nfc on my z3 on the commando it keeps asking me to enable wifi when it is already connected it is above android 4.0 so i don't know if I need to change settings or what on it.
6 REPLIES 6
Are you transferring data through Bluetooth, WiFi direct or am I missing something?
Also is your z3 compact compatible with your carrier LTE frequencies?
regalxdomain
I was able to transfer thorough the computer took a but because I had a Fitch with that too. Also how would you know if it's comparable because I thought LTE was the same all around, we sent for a new one because for some reason this one will have service then it will say no service available from any network. We changed the SIM card. I thought it was just my house because in some areas I would have full connection bit even then it would go from that to noting. Hopefully the new one works better.
Keep us updated
regalxdomain
Yes all is well now everything is working good the thanks
I'm glad to hear that
