Possibly software so you could try booting into Safemode or performing a system repair
Performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data
Does your phone has a protective case or film that might be blocking the proximity sensor?
Do you have an antivirus or taskiller?
Repair the phone with PCC > do NOT install any apps, uninstall any antivirus app
Bridge (for Mac)
