My Xperia neo v has created my 'self-contact' with a wrong number, any solutions?
Repaired with PC companion, the number is still wrong.
that's odd, I thought the number was copied directly from the SIM card
try this
open the phonebook -> long press on Myself -> Edit contact
if it doesn't work backup your contacts then do a settings reset and/or delete all contacts
Make sure you backup everything
Settings -> privacy -> Back up my data and Automatic restore should be selected
and also
Use one of these links to download the
Backup & Restore app
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
How to install it
You need to
download IO File Manager
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
open your phonebook
on your computer
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
or your SMS use
"backup & restore SMS"
or for your MMS use "Save MMS"
Call Logs
And for call logs this is great
My Phone Explorer
https://market.android.com/details?id=com.fjsoft.myphoneexplorer.client&hl=en
An easier way to install the Backup & Restore app
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
or
it doesn't work, because there is no option to edit!
backup everything then
1) open the phonebook -> press menu -> delete them all
or
2) settings -> privacy -> settings reset
or
3) if it doesn't do it then factory reset
i'll try it tonight, but i think this isn't solution. Because when i repaired the software all contacts are deleted. i hope it works. thanks.
Anytime, make sure you do backup everything
Don't master reset your phone just yet. No need for that since I don't think it will help.
This is SIM related and if you cannot edit this you should first of all try with a different SIM card, the newer the better. Just put it in your phone and see if you can edit it or not.
