sd external storage
Maikelz3
sd external storage
Sony Ericsson Xperia Z3 not automatically stores the external SD card, should improve
10 REPLIES 10
@Maikelz3
That's not supported by Android, there might be other apps that might be able to do so, check the play store.
Maikelz3
@uliwooly You're wrong if the Samsung mobile leaves the autosave on the external SD card.
profile.country.RO.title
_alexdon_
Samsung is not pure Android unfortunately, touchwiz has twisted it around like crazy. This has been asked before and some apps offer storing directly to SD like GPS apps.
alexdon
Maikelz3
@alexdon I tested the Z3 Xperia and Samsung Galaxy S6 and better storage Samsung to be automatic external sd
Maikelz3
The Sony Xperia Z3 has plummeted for my taste not incorporate automatic external sd storage.
xavinux
Enthusiast
Hi @Maikelz3
Moving apps to SD has almost no result as apps data is still stored in internal memory. When you move an app to the SD card, Android will only move the apk-file as described here. This is standard for Android and not specific for Sony devices. The path to the obb is for example known by the app so if you were to move it the app may not find it. An SD card is a volatile storage and the data of those app installed in your SD, will also be affected by security.
_alexdon_
You should contact Sony with your suggestion but you need to take this up to Google.
alexdon
@Maikelz3
This is a way to get in contact with Google so they can implement this
http://developer.android.com/support.html
Maikelz3
@uliwooly received thanks
