sd card issues
Cnuk4u
sd card issues
Hi All,
My ST15i not detecting SD Card where my PC is detecting the same.
Please some one suggest the solution
10 REPLIES 10
Do you have another SD card that you can test?
Cnuk4u
Thanks for fast reply
Actually I tried by inserting another SD card also same issue, phone not detecting the card
under setting>storage> it is showing the only option 'Mount SD Card' which is also not an active one
alexrx
Enthusiast
@ Cnuk4u,
You can also try to format the SD card using the phone (backup your important data first).
Go to Settings > Storage > Erase SD card. (similarly as format).
Keep us updated.
Cnuk4u
As phone not detecting the SD Card the only option we are able to see under setting>stoage is 'Mount SD Card' even which is also seen as inactive (just view)
I agree with Alexrr back up and reformat your SD card
Cnuk4u
if it is the case (I mean problem is with my SD card) why some other working (in their phone) SD card also not detecting by my phone???
alexrx
Enthusiast
Have you tried a software repair so far?
That's hard to say, but that should narrow down the issue, it could be a hardware issue with your phone, but if you don't have another SD card, that's the best way to test the issue
Cnuk4u
OK I will check it with service center thanks to both of you for respending to my issue
