SD card Help wanted
urms
SD card Help wanted
Help wanted!!
When opening my camera on the SP it tells me memory error, no memory found. I don't get it because I bought a Kingston 16GB SD card and it's in the phone.... Also I can't open my music and pictures that are allready on the card 'cause I copied them from the laptop to the card. And I can't put any apps on the card. Conclusion: Can't use the card at all....why did I buy it...and why does the SP have this option if it's of no use at all? Any one overhere who can tell me if there is a solution for one or all of my SDproblems? Please let me know.....I am not amused at all Dizzy_Face
2 REPLIES 2
prometej-zg
You've said that you used your SD card on your laptop. Did you format your SD card on it? If you did, then check what format type did you use. FAT32 is probably preferred format type for XSP.  If you want you can try to backup your data from your SD card to PC and then try to reformat it using phones internal  formatting tool and see if its functional.
RenShijo
you should change the format to FAT32....maybe you're using NTFS format..
the phone can't detect NTFS..tried it when i first get it..
