Screen wont work right
Coltspm
I got a bit of water on my sony Xperia z3v. The phone was dead when this happened. I immediately put it in rice and let it sit there for a few days. The i removed the back glass panel because it was cracked and i was going to replace it. Then i turned it on to see if it worked without the back panel. It didnt turn on due to it being dead so i charged it. Once it was charged i turned it on and the screen wouldn't respond to my touches. Then it started acting up and selecting things on its own in a very rapid way. What i wanted to know is how to fix this problem. Is it because the back panel is not on? Please help me because i am a big fan of these phones.
7 REPLIES 7
@Coltspm
Hard to tell, the problem could be due to water damage or it could be because of impact.
Sugna
That's the water damage in your phone. You're going to have to say rest in peace, OR, get a blow dryer and blow dry into the phone and the heat will evaporate the water, you have to hold it there for 10min or so. Put it back in the rice after you thnk you have evaporated the water. If it still does not work, i would advise you to take apart the phone (if you know what you are doing)
You should take the battery out for this.
@Sugna
That's a terrible idea, @Coltspm keep the phone away from heat
Sugna
Don't listen to @uliwooly
You already voided your warranty by taking the back off.
mr_xzibit
Use a hairdryer and fry your phone. I dare you
@Sugna
Your suggestion WILL DAMAGE the phone, that's not ok.
This is a reminder of the forum guidelines
http://talk.sonymobile.com/t5/Welcome/Discussion-guidelines/m-p/349678#U349678
Respect is the Key
Respect is the name of the game. You must respect your fellow members. Please refrain from inflammatory and defamatory comments as well as flaming, taunting and general disrespect. Do not simply put down the opinion or advice given by others. If you don't agree with it, say why - respectfully. Don't just tell them they're wrong. Do not make uninvited remarks about typos, duplicate posts, posting styles, etc. This is not the place to aggressively pursue attacks and accusations on one's chosen style or background. We all have different opinions and different backgrounds.
When an opinion based discussion is being had, do not state things like "there is no argument" as if your opinion is the only one or the only one that matters. When someone has clearly stated their opinion, do not say things like "Are you serious?" and "Are you kidding me?" Remember, this is not a debate club. This is a friendly discussion community. Allow people to have their opinion. No one is to act as some sort of opinion judge, responding to each one to say whether they agree with it or not or whether or not it is a valid, well thought out opinion.
Curnow1
Thats water damage. Back glass has nothing to do with the touch screen , Only NFC.
First try dong a Software repair with the xperia Companion if it wont work do this :
Since it was in rice and the screen is not working try doing this :
Since your Back is already removed
Turn off your phone.
There will be 5 Flex cables on the phone motherboard 1- Camera (Top left corner) 2- Top microhpone & 3.5MM jack (top right corner)
3- Battery Connector (Its placed right over another connector so they're very close) 4 - under the battery connector i think its to the Magnetic charging port. 5- Screen , Buttons , buttom speacker connector its the widest connector on the motherboard
Unclip the 5th Connector ( The widest) and 3rd Connector ( battery connector) wait a minute , connect them again and turn on your phone.
If it wont work follow all these steps to dissassemble your phone : https://www.youtube.com/watch?v=9ZLLChEXzWk
You dont have to remove the screen. Just clean the connectors with a 100% alcohol cloth and put it back in rice for a few days.
