Screen won't display anything when waking
hippiewithnosho
My Z3 keeps failing to display anything when I wake it up. The backlight comes on and it seems like it's functioning, but nothing is displayed.
Every so often if I keep pressing the power button on and off the display will come on (usually when at full power and plugged in), but otherwise I get nothing.
I've tried power and volume+ resets, but it doesn't help.
Any ideas?
Thanks,
3 REPLIES 3
Thommo
Genius
Try performing a system repair as this will often fix issues - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
hippiewithnosho
Tried this now, but when I turned it on after the reset there was still just the backlight and nothing being displayed
Jack1811
What did you end up doing? Mine is doing the same, it's very frustrating.
