Have you checked safe mode?
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
Keep us updated.
You may need to perform a software repair using PC companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
Not 100% but I do have some hopes.
Now I'm charging the phone till 60 % and then I will try
I will inform you
Give it more than 60%.
