Hi
Got a really annoying problem with the screen, every time I close my case it turns off the screen is there a way of stopping this
Thank you
Which case are you using? By default, there are no setting to turn of this feature. If you have installed an application for the case, it might be a settings for this in the app itself..
Hi there its just a normal case I haven't got any apps related to this
Chrets
Unfortunately, then it's not much that you can do since this is how it works by default.
Okay 👌
Are there any cases that let you do this as you asked which case I had?
If you have a cover which is made for Z3 tablet, it often has a magnet at the top which will make the screen go black when you close the case. But I have heard that some covers do not have a magnet, then the screen should not go black when you close the case.
