screen lock
Thorin24
screen lock
He carried the phone in his pants pocket, unlocks and makes me emergency calls. also access the notification bar, turning off or connecting flashlight, wiffi, 4g ...
You can correct this error?
10 REPLIES 10
@Thorin24
make sure that the screen is facing away from your body and also disable double tap to wake
Thorin24
put the screen into my body to avoid injury from stroke. I have enabled unlock pattern. fortunately, does not unlock my phone, but it makes calls to emergency numbers and acede the notification menu and activate the wi-fi, bluethooth, NFC ....
@Thorin24
There's nothing wrong with your phone, disable double tap to wake
Settings > Display > Tap to wak up > Off
Thorin24
that serious option in the menu in Spanish? I do not understand
@Thorin24
I'm not sure if your Xperia E5 has this option, I assumed it did.
Thorin24
some days I searched the menu and find no option to disable notification bar on the lock screen, I can not be like using the proximity sensor to keep the locked screen and avoid these accidents. (This week have changed settings, such as the clock, I have sent emails ... all with the phone in your pocket)
Note: If you do not know Quie talk, do not answer. It's annoying and no doubts or concerns are resolved.
YoGem
Leader
Thorin24, I believe you are using Google translator to post your question in this forum... Is your main language.. Spanish? Se que los moderadores de este foro me van a matar (hahaha) pero si tu hablas español posiblemente yo te puedo ayudar Slightly_smiling_Face
Thorin24
si @YoGem hablo español. seria de agradecer una ayuda, este problea me esta fastidiando mucho. Gracias.
yes. @YoGem Speak Spanish. assistance would be appreciated, this problea this bugging me. Thank you.
YoGem
Leader
Sorry for the delay, I sent you a private message in Spanish. Let me know what's the issue with your phone, I'll try to help as much as I can!!
