Screen lock while in call bug
What-Steve-Did
THE most annoying bug for me so far - I got the phone set to automatically lock (pattern unlock) after 2 minutes of the screen being off. If I receive a call, proximity sensor hits the screen off as you'd expect. 2 minutes later I have to wake the screen manually with the power button, unlock it just to be able to end the call.
18 REPLIES 18
profile.country.RO.title
_alexdon_
maze,do you have a screen protector or flip case?
alexdon
maze
Neither. Though today I did notice that it didn't shut the screen off on every call. I will monitor it.
_alexdon_
Good,keep us updated.
alexdon
Sandeep_Banerje
I have password screen lock setup on my Z2. When I receive a call, and click Home, I get the lock screen. Though the cursor is in the password box, I cannot bring up the keyboard, and therefore cannot access any app.
Sandeep
_alexdon_
ETE
I have a similar issue which is quite annoying as it takes a long time to end the call. Is there no way one could use the side power button to end a call swiftly without having to go through the main screen?
Ayl
I do face the same problem. It is very hard to end call or put phone loudspeaker
AndrewKozman
Same issue screen screen turn off while in call and couldnt even be woken up
Rickard
Do you have any cover or screen protector on the phone? These can cause this issue if they cover the phones proximity sensor.
I've seen that there are some 3:rd party screen protectors that doesn't have a hole cut out in them where the phones proximity sensor is located for example. These can cause this issue.
