Haven't had a screen lock pin on my tablet for a while and after the last update I turned it on and asked me for a pin I entered my last pin I did have. Buy wouldn't take it . I do t have device manager or what have you installed on my tab. Can't get into my admin account to reset it to factory please help me ;+) thanks
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery.
