Screen darkening 3-5 seconds then comes back. I've not had this problem once multiple times,
Does this happen when you aren't running a bench test because that's what a bench test will do
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
You would need to either return your device to the place of purchase or contact Xperia care and have your device inspected http://www.sonymobile.com/global-en/support/contact-us/
u just bought one of the worst sony phones, as many of us here did.
