screen capture, volume slider
jaydee1
I update my Xperia SP last Friday. It was doing great and I loved the added customization options. But I just found out that the screen capture option is gone (it used to be with the power off and airplane mode options). I've tried the volume down and lock button method but it also doesn't work.
And the volume slider doesn't show up when I press the volume rocker, only a black rectangular box. Is it the same with the other updated SPs?
2 REPLIES 2
Danial-mach1
Leader
For screenshot use power button+volume down you must push them together try it you will learn how to use
This is The problem for downloaded themes...chenge theme to default theme and reboot your phone
IMR
Wow thank you vvvv... Much.
