Screen brightnesst reverts to ~30% after disabling auto brightness.
Aran
Hi, I have an xperia l.
I discoverd a bug when swithcing brightness using the widget.
here's what happens:
1) Uncheck automatic brightness adjustment
2) Set your brightness to lowest value
3) Now use the widget and toggle high brightness
4) turn off high brightness using the toggle widget
5) the brightness u set at low now reverts to ~30% and its supposed to be the lowest value
gigavolt
Hello. It is probably not a BUG, but incapability of developers to create it logically.
There is also problem with "brightness automatic setting". It is deactivated, when mentioned widget is used. In Android 4.1.2. it was good, in 4.2.2. 15.3.A.1.12 it was totally wrong, in 4.2.2. 15.3.A.1.14 it is repaired, but with this issue. It is not a BUG, it is incapability to make it correctly.
