SCENARIO:
1. I adjust the screen brightness via Settings to e.g. 75% (slider). The phone responds correctly.
2. I use the Application widget to switch off the Backlight. The phone responds correctly (turns darker).
3. I switch on the backlight. Then something unexpectedly happens: the screen brightness turns to maximum.
Using the Automatic checkbox along with the screen brightness slider does not change the situation.
I believe the phone should remember the screen brightness setting? Currently it only does that as long as you don't touch the Backlight switch...
Unfortunately this is simply how this widget works. The two options do not talk directly to each other.
