Screen 'app' drains battery
WellWel
Hello there,
I got a small problem. My battery keeps draining fast, and when whatching the battery stats the screen apps drains most of my battery. This while I didn't use the phone much at all (58 mins), and brightness as low as possible.
Wakelock detector gave these wakelocks. I hope someone can help me.Screenshot_2014-11-22-00-14-53.pngScreenshot_2014-11-22-00-19-28.png
6 REPLIES 6
profile.country.RO.title
_alexdon_
Can you check if the same occurs in safe mode?
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
alexdon
WellWel
This is a screenshot in safe mode. Screen has been on for about 3 minutes. Still draining quite fast.Screenshot_2014-11-22-14-09-29.png
_alexdon_
You may need to perform a software repair using PC companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
alexdon
WellWel
Thanks! Will try that!
WellWel
My phone battery still drains really fast.. Wakelock detector shows that the telephone app is draining quite much via data dormancy, don't know whether this could have anything to do with it?
_alexdon_
You should stop by a sony service:
alexdon
