Scheduled Do Not Disturb
Obsidian_Eclips
Stock lollipop 5.1.1 on m2
When you set a scheduled "Do Not Disturb" with "exceptions enabled", "calls and messages from favourite contacts only" and the sliders set for calls and messages; the phone enters silent mode at the scheduled time instead of priority. None of the favourite contacts notifications come through. The icon displayed on the notification bar is the circle with a line when it should be a star.
I have tried disabling and re-enabling "do not disturb", ensuring favourite contacts are starred, I have even factory reset the phone and reinstalled with pc companion but the issue remains. A scheduled "Do Not Disturb" never enters priority mode despite being set to do so. If I manually use the volume key I can bring up the menu for priority and allow exceptions that way but a scheduled one does not (I reaffirm it is toggled to do so on the Settings /Sound and Notifications / Do not Disturb menu with the sliders for messages and calls also toggled on)
Is this a fault? Other devices I have using lollipop work fine with Do Not Disturb. The M2 seems to ignore the toggle. Will there be a patch?
3 REPLIES 3
profile.country.RO.title
_alexdon_
Is this what you experience?
/t5/Xperia-M2-M2-Aqua/Smart-Connect/m-p/1045121#M7580
alexdon
Obsidian_Eclips
No, this isn't anything to do with smart connect. This is under settings/Sound and Notifications/Do not Disturb. When using a scheduled "do not disturb" the device ignores the "exceptions" slider and enables silent 'wihtout' engaging priority - the other thread talks about there not being a silent option for the z series.
When you manualy use the volume slider to engage "do not disturb" you can select "exceptions" and it works fine. But it will not engage automatically using lollipops own schedule (this works fine on other lollipop devices I have - just not Sony m2)
Yks
Almost the same here! When scheduled do not disturb is set, it does not always turn on at the specified time. What is even more strange: at this case, if I modify the starting time, it gets fixed - for that day. The same problem with the ending time.
