I have SBH52 and Sony XBA-2VP headset. Acording to following review it should use in line microphone of the headset when using compatible headset.
http://recombu.com/mobile/news/sony-sbh52-review_M19403.html
But I tried several headphones with mic built in. It only uses ic of the unit.
The information in the review is wrong? Anyway of getting the mic of the headphone worked instead of unit mic??
I have a similar problem.....When I insert the headphones jack the device comutes on the upper side speaker and uses as a mic.The quality is not the same and my friends complains that they hear me bad:(
Me too facing the same problem ECO sound or low sound problem replaced the headset but still having the problem even i have to select sim for dialing with my Xperia T2 ultra then there is no use of bluetooth headsets...
Sony have to fix the issue of low sound & dual sim dial complaining from last month but there is no solution service is too poor i didnt expect this from SONY.
