root problem on Xperia p
rooniek13
i cant root my xperia p .  At first i set in settings debugging mode on and unkmown sources too,so i cant understand why the programs cant see that debugging mode is turned on(
I tried to root with "root with restore by bin4ry" and flshtool too. in the first one  :
= This script will root your Android phone with adb restore function =
= Script by Bin4ry (thanks to Goroh_kun and tkymgr for the idea)     =
=             Idea for Tablet S from Fi01_IS01                       =
=                      (20.09.2012) v11                              =
Device type:
1) Normal
2) Special (for example: Sony Tablet S, Medion Lifetab)
x) Unroot
Make a choice: 1
Checking if i should run in Normal Mode or special Sony Mode
Please connect your device with USB-Debugging enabled now
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
and in flashtool  :
16/002/2012 12:02:22 - INFO - <- This level is successfully initialized
16/002/2012 12:02:22 - INFO - Flashtool Version 0.9.9.0 built on 2012-11-13 22:53:30
16/002/2012 12:02:22 - INFO - You can drag and drop ftf files here to start flashing them
16/002/2012 12:02:25 - INFO - Device connected with USB debugging off
16/002/2012 12:02:25 - INFO - For 2011 devices line, be sure you are not in MTP mode
3 REPLIES 3
Miltos95
You're on ICS right?
Make sure the adb Drivers are installed and USB Debugging Mode is On.
Under device management on Windows it should say "Sony Ericsson ... ADB Interface Driver" somewhere.
Follow the Instructions in the Program, if all goes well it should tell you to Restore a file called "RootMe"(?). Let it do a couple of restarts and you're good to go when the program says it.
Also if the PC Companion is running, shut it down and try again.
AhmedBinAmer
I have the same problem...it gets on debugging mode when I turn on usb thethering :X....weird but true!!
