Roaming problem
Menzi
Roaming problem
Good day, would just like to ask help regarding setting dual sim.. Am from Philippines and using sim1 as my native sim (smart), came here to Japan and inserted on sim2 their native sim (docomo). Why can't I receive simultaneous signal on both? I can receive signal on each if I set them to lte but the other will automatically set to GSM only which then loses signal..
5 REPLIES 5
profile.country.RO.title
_alexdon_
That is how dual SIM dual standby works. Second SIM will be set on GSM only.
alexdon
Menzi
Thanks for the quick reply but what I meant was I loose signal completely on the other sim.. I needed still to receive calls and text on the gsm only...
_alexdon_
While you are on a call on the first one,you will show up as busy on the 2nd one. There should be some kind of smart call handling though.
Dual SIM smartphones come with many advantages. They allow you to separate work and play – and handle your calls more cost-efficiently. With our new dual SIM feature you can talk on one SIM and still receive calls from the other, instead of going to voicemail. This gives you the option of putting the first call on hold while answering the one coming in. So you need never miss a call. You activate the dual SIM feature when you set up your phone. If you add your second SIM card later, you can always access the setup guide from the Settings menu.
Still you say the 2nd one is out of reach when you are on the first one?
alexdon
Menzi
Yes... Out of reach on the 2nd one if I choose data on 1st (and vice versa)...
_alexdon_
I think this is how it should work unfortunately. Get in touch with sony:
alexdon
