After my latest update of Android version 14.4.A.0.108, my ringtone volume gone low. I could not hear the incoming calls, as i miss most of the calls. Please help me with an solution.
Strange,this does not occur on Z1 on .108.It was on .757 if I remember correctly but it was fixed.I suggest you to try a software repair:
Has your phone been in contact with water? if it has, let the speaker dry out
I have done the repair as well. Still no change in the ring volume.
It is almost 2-3 weeks over, so i dont think it should be because of water. Eventhough water is there, it should have dried out by this time.
I went to Sony care since i was having ring volume issue after android update, currently the ring volume is low that i miss lot of incoming calls. I also had the usb port flap got removed. When enquired they say that since the flap is removed the entire produce is out of warranty so even the repair for the ring volume will be out of warranty. I could not understand the logic behind this. I am ok to pay for usb flap, not for the ring tone issue.
Sony care, Egmore, chennai, India
You should ask to speak with someone above that person, it doesn't make sense
