PLEASE HELP, SP RESTARTS CONTINOUSLY.. BUT WHEN RESTARTING ALSO WHEN LOADING THAT XPERIA FIRE IMAGE OR GIF KINDA THING IT HANGS THERE ITSELF.. AGAIN RESTARTS.. EVEN IF IT LOADS TO THE LOCK SCREEN , TOUCH IS NOT WORKING.. AFTER SOMETIME IT AGAIN RESTARTS..
PLEASE HELP.. WHAT TO DO.. :(:(:(
Try removing the Sim card and testing and if that fails then
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone
and if the above fails then you need to either return your device to the place of purchase or contact Xperia care http://www.sonymobile.com/global-en/support/contact-us/
You could remove both SD and SIM cards and boot on safe mode
Don't forget to backup
Bridge (for Mac)
