Hello!!
Guys do you know how to reset the settings only on Xperia Z2?? I don't what anything to be erased or deleted permanently! Like in old Sony devices, you had a choice a hard reset and it will erase everything or just the settings na dnothing more
There should be factory settings reset, but that will remove everything unfortunately. You can try settings-apps-all, look for settings app and clear data. Let me know if this resets everything you have changed in settings.
You could create a backup an then reset the phone
Bridge (for Mac)
Emm not really 😕 I try to change many settings Sound, screen... and many other settings.
I went to apps and i press ''Reset app preferences'' i think it was that you mean. Didn't change my settings to default 😕
I thought there is easyer way to do it and don't mess up with Back up just for reset setting to default 😕
No, not reset app preferences. Follow the steps exactly as I have told you.
You will have to repeat that on all the apps or just reset the device but create a backup
Ok i did, i went setting, apps i found the setting and i did clear date on it. The only thing that i noticed was it just turn the setting off and it drop me into main menu. Didn't see any changes on settings 😕
I see your point
