You need to develop 2 shortcuts one to enable users go directly from screen into favourites and the other to go directly to call log. Having to go to phone and then favourites is a drag.
You also need to do an upgrade to enable customers dial directly from favourites, rather than having to open the contact (or press the icon to get another menu) and then dial.
Smartphones should be as quick and easy to use as the old none smart phones, and should (for the time being) be optimised for voice calls (or at least customisable to be optimised for voice calls)
long press the any empty homescreen space , select widgets
add favorits and call logs widget
try it....
it will give you the favorites on your homescreen.. no need to go to phone....
the second one is a must.... i agree..
