I have just changed Xperia Mini Pro for new Ray (didn't get on with small handset) but now still have the User Guide which I had down loaded on my new phone. Does anyone know how to remove and/or change the User Guide?
Did you move your SD card from your old phone to your Ray?
If yes, I think the users guide is located on the SD card and that your Ray reads it from there.
I don't think that there are any SD card adapted users guide for Ray.
Thank you for your prompt and helpful response. I did move my SD Card, so suspect your assumption the User Guide is being read from there is a correct one. Although this may be a rather simple question (I suspect I may know the answer) but is there a simple way of deleting the user guide from the SD Card, either using the phone or on my PC? If I can delete, the I should be able to download the correct user guide starting fom scratch. Many thanks,
Regards, John
Rather belatedly thank you for this. I know where to find the User Guide, as I mentioned I have previously done so. However, I don't know how to delete the existing User Guide (for the Xperia Mini pro) which still resides on my phone. I have tried to download the correct one but it doesn't overwrite the wrong one.
you can either mount your SD card to your computer and look for it, or use OI File Manager from the market and look for it and remove it
