Regarding Sony Xperia E dual
Anshuman8290
Dear Team,
                     I am using sony xperia e dual its rooted but whenever i make a call or switch from one task to another the screen shrinks from borders showing a broad red outside border also when on call if i try to add people on conferrence via contacts it dosen't works but when i manually dial the mobile no. then it works.
    Kindly suggest what  should i do in order to overcome these problem.
Thanks,
Anshuman Singh
Johan
I suggest that you try to reinstall the phone software using Update Service..
You will lose your root access by doing this but it may fix the problem.
