Refreshing very slow
I have been facing few problems with my Xperia S lately.
I had the heat problem and Nabeel informed below 50 degrees C is fine so I am OK with it.
Now, from past few days, when I press on Phone icon in the home screen it takes 5-6 seconds to display the phone menu screen and when I return back to home screen, the icons are not displayed immediately.
They are popping up (displaying) after 2-3 seconds.
I have tried resetting to Factory defaults and it worked fine for 1 day and again I am facing the same problem.
I went to the SE customer care center and dropped in my phone and got it back after 2 days.
When I received the phone it was pretty fast and I was very happy and it didnt last for more than a day.
I am attaching a screenshot for a reference.
Now I am facing the same problem and I dont understand what to do.
If anyone faced the same problem and has a solution it would be great.
Thanks
Sandy
3 REPLIES 3
Markus1
Leader
Sorry to hear this.
I would like you to try something. Go to Settings > Apps > Manage apps > Xperia Home > Clear data.
This will reset the home screen meaning all widgets, shortcuts etc. will be restored to default.
When you've done this, do not re-add any widgets for a few days and see if there's any improvement.
Let me know.
Hi Markus,
I have actually browsed through other forms and I found a solution for this problem.
If we are facing this problem, then we have to switch off the mobile and on it back after 10 mins.
It works like a charm but I dont know if we have to keep doing this frequently or not.
Coming to your solution if we clear all the widgets its of no use using Android phone.
I will remember your solution and will try it if I face the same problem again.
Markus1
Leader
I wasn't really suggesting it as a solution but rather a way to determine if all the stuff on the home screen are causing this or not.
If you've found a different way of solving it there's no need to try what I posted though. Slightly_smiling_Face
