heyo community,
5h ago, my phnone ( sony xperia z3 black ) dropped from 1m 60. after that the screen turned black and there wasnt any sound. as soon as i plug it into the charger ( original and working) the massage-light turns red and it stays red untill I unplugg the phone. does anyone knowes what's going on?
Thanks fpr your support
btw sorry for bad english
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
If the above doesn't work then I'm sorry to hear this but you would need to either return your device to the place of purchase or contact Xperia care and have your device inspected http://www.sonymobile.com/global-en/support/contact-us/
sony pcc cant find my xperia 😕 i cant do the restart or something like that because i tried pressing both louder and off but it doest anything
The device isnt proof or resistant to drops. Its light and thin. Something inside of the device could be damaged. Maybe some connector or worse. Your only solution is to contact sony and ask them to open the Device and check whats going on
