Recovery
thejavigames
Recovery
hello good as you enter the recovery menu? pulse power and volume + and vibrates 3 ​​times but does not enter recovery
It vibrates 3 ​​times because there is some risk or other function ?
9 REPLIES 9
Jake-SonyXperia
Hi thejavigames,
Welcome to the community,
When it vibrates three times this means the device has simply powered down. What are you actually trying to achieve with the device we may be able to help.
thejavigames
thanks for the welcome. I 'm trying to find out how to enter the recovery to factory wipes .
the vibrations of the 3 does so with more power + volume off but that still does not fully understand the power goes off
Thank you
Jake-SonyXperia
I don't believe this can be done be default, the only way I know this to be achieved is through the following link.
Developer world
thejavigames
Okay thanks then if there is no recovery to do a wipe data / cache , to leave the factory flashtools pccompanion would be used or not?
forgive my English , I'm Spanish and use google translator Slightly_smiling_Face
@thejavigames
Keep in mind that if you unlock the bootloader you will lose the DRM keys.
thejavigames
I was not going to open , then to leave for necestiria manufactures flash the rom with flashtools or need also open the bootloader ?
pccompanion because I think you need to boot the OS right?
also do not need that , it was just to inform other terminals because if they carry recovery
thanks and regards
Jake-SonyXperia
You can use PC Companion to reload software, however that is really going to depend on if you have flashed the handset with another Rom or if you have unlocked the bootloader, both of these functions will result in PC Companion no longer functional for you.
jani1
Hi, Jake Sony Xperia Support... Do you know anything about MSC mode? According to Sony Hungary and Sony Xperia on twitter the phone has MSC mode and we should see the option to enable it under Settings but that menupoint is not there. When do you plan to fix it? The current MTP mode is unsafe, even deleting a folder hangs any Windows program.
thejavigames
My bootloader is stock, closed.
Use pccompanion or flashtools for flash rom stock?
