Hi all, I have been noticing this wierd problem on my sola.. when a call comes, i swype to recieve it but it does not get recieved, goes on vibrating and after only a couple of seconds, it shows that the call is active.. Is anyone else facing this same problem.. It is really annoying.. Even the recent update of ICS they did not sort out this problem.
Yup same problem... It takes about 5 seconds for the incoming call screen to load up... then takes another 5 seconds to pick up the call
Hi there.
On this, check the amount of RAM memory you have left.
This is done by going to Settings> apps> "Running" tab.
If you are running under 100mb the phone;s response time slows down.
To remedy this please free up memory by deleting some unwanted apps or by using a Task manager.
Hope this helps.
Francis.
I have the same problem, and when I go to running apps, the settings crashed and it says settings stopped working! how do I fix that?
I would advise you run an update/repair:
and install it on your PC.
4. Phone Software Update.
5. Start.
6. Repair Phone
7. Continue
8. Accept data removal
9. Next
10. Wait for prepare
11. Select Phone
12. Follow the connection steps
another thing, you say if RAM memory is under 100 mb the phone slows down..
but, my phone is alway about 40 mb of RAM, I go to task killer > kill all apps and in a few minutes all apps automaticly turn on and use my RAM memory! how do I fix that? how to disable apps that they dont open automaticly- apps such as music player (that I dont even use), whatsapp,contacts, ?
and repairing softver didnt help, settings still crashed after going to settings > apps > sctive apps
You said to free up RAM but how many times do we do that ?? I have a very few apps installed, i get RAM around 130 mb... Even games dont work properly, the basic games infact. they all crash. I am totally disappointed with the phone (thought it will fast seeing dual core n stuff) but it is not at all.
Even i dont know how to not make apps active which we are not using... I guess it is not possible in Android but the most basic function of phone that is to recieve n make calls, if they only dont happen what is the use of buying such phone ??
receiving calls is a little b i t h a r d on sola.
Every time someone call to me I must wail 4s because if I say "hallo, what's up" someone hear only "...s up"...
It's something audio microphone input related.
