Hi, my phone has been stuck in a reboot loop .It reboots every 20 seconds or so, shows the sony logo, the andriod screen and then starts with blue "waves" welcome screen , then restarts. it doesnt remain functional enough to use the pc companion - as it reboots so frequently the software cant detect.
i've tried hard turn off (volume up and power, as well as the button under the sim card slot, loading with the sim and sd cards in and out and every combo.
any advice? pulling my hair out...
Hi rymac14,
Welcome to the community,
Can you advise what happens when you hold the power button and volume + key for around thirty seconds, is the device vibrating three times and if so does it simply start the loop again?
Hi Jake - me, but on another account.
Yes, it vibrates 3 times and turns "off" . when i turn on , it goes back into the loop.
Ryan
This sounds like a Boot loader issue, in this case I can I really suggest a software repair. This can be done with the device powered off. Try using the steps below.
Note: make sure the handset is not connected to the PC until the last step.
Here's how to run the repair on PC Companion:
2. Phone Software Update.
3. Start.
4. Repair Phone
5. Continue
6. Accept data removal
7. Next
8. Wait for prepare
9. Select Phone
And Bridge for Mac:
2. On the Main Window select "Xperia > Repair Xperia Device".
3. Ensure the phone is charged and select "Ok" in the following window.
5. Wait until the initialising step is finished the continue as below.
7. Follow the connection steps that appear, ensuring that you are holding the relevant button down before during and after the connection phase until the update/repair begins.
