HI ALL,
i have been facing a problem for last two days. I updated my Xperia P to JB using pc companion. It was working fine. Suddenly there was an issue in the morning the day before yesterday. It suudenly started to Reboot automatically.
First the logo of sony and xperia comes and dissolves. Then the default loading wave of xperia appears but instead of going to the lock/home screen it starts the booting process again and this process repeats.
I switched off my phone using lockkey+volume up. i tried to update/repair my phone using PC copanion and Sony Update service. Both case the latest software is downloaded and installed. But after installation when i try to switch on, it goes to the menu screen normally and asks me to select time format, language etc... but suddenly it starts to fall on the reboot loop again and then never goes to the main screen
What should i do? Try to flash my ROM?
Plzzz help
Sorry to hear about your problem. Sounds like you should send your phone to a service center to get your phone examined. Please contact your local support for more information:
not at all
tried every possible thing ... including upgrading and downgrading ... problem persists
for the last try i would root it ... dont know if this is a hardware problem
frustrated!
flash the stock ftf file and wipe data, cache, dalvik or root it and flash custom roms and check ..
could you please share the link of the stock ftf that you are talking about?
Thanks in advance
https://mega.co.nz/#!ngwBARRJ!H_XrsU5RH9iGN-iH3COmRlXf2xImsSnXy7DpJ4wYT3A
download this and then use flash tool to flash this downloaded file !!
Thank you again!
1. Should i wipe cache before flashing this ROM or after flashing?
2. Is it enough to perform 'factory reset' to wipe cache, data, dalvik cache or i need to do something else/extra?
Thanks in advance.
using flashtool automatically wipes data, cache, dalvic .. if u don change any settings !!! the default settings always performs a clean install !!
