Re: Xperia P Backingup Problem
terryl2862
Tried re-install PCC. But again same problem happened. Regardless I back up everything inside my phone or just 1 file, phone HANG definitely during backup
Help. Has anyone else come across this problem??
5 REPLIES 5
Hampus
Is it your phone that hangs or is it PC Companion? If it's PC Companion you can let it stay open without forcing a shutdown for the program. If you back up a lot of data, it looks like the program hangs for a time but it's actually working in the background.
terryl2862
is PC companion hang.
Even if I let it stay there for a while, either it continue hang until I shut down my laptop OR back up error OR back up data - 0 mb. =.=''
Tried few times... even tried in different laptop but all end up with the same problem.
Hampus
If the same problem occur on different computers and you have tried to back up one file at the time, there might be something fault with the device. I suggest that you download a back up application to your phone, for example MyBackup and perform a back up from this application. You can also move the back up file to your PC afterwards.
When the back up is done, you can perform a software repair on your unit via PC Companion. In PC Companion you press start on Support Zone > Start on Update the phone/tablet software > Repair phone/tablet (the blue clickable link in the message) > Follow these steps without having your device connected to the PC.
terryl2862
I wonder is this backup sufficient enough? And this backup include apps installed in my mobile? If no, is it possible to include? how? Thanks Slightly_smiling_Face
profile.country.RO.title
_alexdon_
Yes,it should be enough.But to be more sure,try myphone explorer to save messages.
alexdon
