Radio Disabled
Radio Disabled
Hi, I noticed, in use of battery details, that there was a percentage of battery used by radio as an inactive device. I tried to stop the app by plugging headphones and switching it off, but the battery was still used by the radio. I disabled the radio in applications settings and now I can't find the radio app but the battery is still being used by radio as inactive device.
Can anybody help me?  Thank you
8 REPLIES 8
Markus1
Leader
The radio listed in battery use is not the FM radio. This is the network radio, the one keeping a connection with the network. If you manage to turn this off you're basically in flight mode with no contact to/from the phone available.
Ok, thank you very much, now I have a new questio, how can I have the radio-FM "re-enabled"? I can't find the app anywhere
Thank you!
Markus1
Leader
Go to Settings > Apps > Manage apps > All (tab). Scroll to the bottom and see if you can find FM-radio here and see if it's inactivated. If it is. tap on it and then tap on Activate.
no, I've already tried that and the app is not there..
Markus1
Leader
Do you know how you did to get rid of it first place?
Yes, I went to Settings > Apps > Manage apps > All , looked for Radio and there there were two buttons, I don't know how is the label in English, in Spanish is "Forzar Detención" and "Inhabilitar", in English might be something like "Stop" and "Disable". I pressed "Inhabilitar" and Radio dissapeared forever!
Markus1
Leader
If you did tap on "Disable" it should still be in the list of apps. The disabled apps should all be at the bottom.
If it's not here you need to run a software repair to get it back. This is done with PC Companion. This will wipe the phone clean of user data so make sure to backup all data you wish to keep before doing this.
Thank You!
