After updating to Lollipop ,my M2 Aqua has been giving me some trouble. The phone often has trouble to connect to WIFI after standby and there is a Exclamation mark beside the WIFI symbol. I had never any problems in Jellybean. It often frozes also especially when browsing. Sometimes it also won´t show the keyboard for text input.
So my experience is that the Lollipop have made my phone worse.
Thx I`ve looked at the links but none has solved my problem. I have to emphasize that everything worked BEFORE the Lollipop update. Nothing else has been changed /updated /altered on the phone except Android version and the problem came instantly after updating.
Try this if it helps :smileysmileywink:
I´ve managed to isolate the problem due to Stamina mode. When Stamina is disabled,then WIFI is working fine /normal and no exclamation mark.
When Stamina is enabled,then the problems occurs.
So I have to choose between bad battery time and good WIFI or bad WIFI and good battery time.
Thx Sony for that !
