"Continuously says "android is starting" after startup.
Itsjojobroh
When I restarted my phone after I was notified it took a while to turn on and now it gives me a black screen with the message "android is starting, optimizing application x of 200 " and as soon as it reaches 200 it starts again with application 1 and has been doing this for 8 hours,
7 REPLIES 7
Jake-SonyXperia
Hi Itsjojobroh,
Welcome to the community,
Can you try boot to safemode before it boots in to normal mode.
Safemode instructions
Itsjojobroh
Thanks, but the problem is my phone never even reaches the point where I can boot it to safe mode . On start-up , it basically shows the Sony Xperia(black screen) then powered by android and that wave thing all the Sony phones do and then goed to a black screen that gives me the android is starting message.
@Itsjojobroh
Charge the phone and repair it with PCC
PC Companion (PCC)
Bridge (for Mac)
Jake-SonyXperia
I agree with Uliwooly, a software repair sounds like the best course of action.
I have supplied the instructions on use for PC and Mac below.
Here's how to run the repair on PC Companion:
2. Phone Software Update.
3. Start.
4. Repair Phone
5. Continue
6. Accept data removal
7. Next
8. Wait for prepare
9. Select Phone
And Bridge for Mac:
2. On the Main Window select "Xperia > Repair Xperia Device".
3. Ensure the phone is charged and select "Ok" in the following window.
5. Wait until the initialising step is finished the continue as below.
7. Follow the connection steps that appear, ensuring that you are holding the relevant button down before during and after the connection phase until the update/repair begins.
mrsevans101
Spoiler
I'm having the same problem with my phone. I can't get it to connect to PC Companion for long enough for the software to do anything (before it starts with "android is starting" again). If it does start up then any app I open crashes/stops.
Any suggestions?
I've only had the phone for a couple of weeks and until now I was really impressed. Now... not so much.
Jake-SonyXperia
Hi mrsevans101,
When you are performing the repair, are you making sure to keep the handset turned off at all times as well as keeping it disconnected until the last step?
nischs_srst
same problem here , and also tried pc repair but didnt get any solution , plz help ...
